Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
top timing chain covers, i wasn't happy with ether of them, had to take the left one off and put it back on a gain to get it in line
24th Apr 2019 2:01am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I think there is screw you can remove from the front upper timing covers which enables you to check the timing against the cam trigger wheel but don’t know if it can be done with the top cam covers on or even if it is correct what I’m saying. I know the screws in question but don’t know the procedure , that is a lot of don’t knows I appreciate .
24th Apr 2019 8:46am |
After reading a lot of those posts, I have come to the conclusion that the position of the crank has nothing to do with it.
24th Apr 2019 12:20pm |
Essex1959 Member Since: 21 Feb 2019 Location: Wales Posts: 20 |
Quote:I still have to fit the right park/flasher light, over the last few days several people have tried to get there hand in and put the plastic nut on, but so far no look
24th Apr 2019 7:59pm |
I think the crankshaft position sensor determines the rpm of the engine, not sure what else it does.
24th Apr 2019 8:10pm |
The Chinese set i had were modified by the previous owner as they were in the wrong place so he used a known good set to set the timing wheels and then moved the arm of the wrong set to match the engine and then fixed it in place. the actual locking blocks were ok, it was the trigger whel jig that was wrong on one bank.
24th Apr 2019 8:29pm |
If I had to guess I would say bank 2 or right hand as looking at the front |
24th Apr 2019 11:30pm |
HMMMMMMMMM different side to mine RR 2005 4.4 petrol
25th Apr 2019 1:11am |
It was only a guess, I’ll have a look in my garage when I get time to move stuff so I can get to the box. |
25th Apr 2019 7:10am |
i know the feeling RR 2005 4.4 petrol
25th Apr 2019 9:34am |
How does it sound and drive, is it missing or does it just say it is missing ? |
25th Apr 2019 8:53pm |
thanks i did look at removing the air filter but didnt think it would help, i will remove it, now you have said that and give it a try RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
26th Apr 2019 2:41am |
Essex1959
26th Apr 2019 12:43pm |
Glad you are sorted I have big hands and managed to screw the nylon wingnut on with the filter box removed. Your hands must be like shovels |
26th Apr 2019 1:15pm |
