![]() | Home > Technical (L322) > How many fuse boxes, and where are they? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Third fuse box in the glove box. In at the back. John
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6818 ![]() ![]() ![]() |
Behind a black cover that's hard to see |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
There is another (maxi fuses) on the firewall in the engine compartment (somewhere behind the battery) .
Tight777 Member Since: 26 Jan 2018 Location: Epping Posts: 88 ![]() ![]() ![]() |
So I assume the battery needs to come out to access it? |
I would guess the "ignition relay" is in the big black box with 10 screws .
"I would guess the "ignition relay" is in the big black box with 10 screws"
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2723 ![]() ![]() |
I expect it to be in the passenger compartment fuse panel where it is in the RRS of the same era. |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 91 ![]() ![]() ![]() |
Looks like a different car to mine, and LHD.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
No Sir the diagram above is 2010-2012 (assuming it's L322)-- you have the front fuse box in your picture |
To remove glovebox .
