Home > Technical (L322) > How many fuse boxes, and where are they?
Tight777
I'm looking for the ignition relay in a 2007 TDV8.
I've found a fuse box in the rear offside boot box, and one under the bonnet beneath 10 screws, are there any others hidden away?
I coud do with a diagram for the relays but can't find one for a 2007 Vogue.
Post #513969 2nd May 2019 12:27pm
Weegie
Third fuse box in the glove box. In at the back. John
GAP iiD BT-Sold
Post #513975 2nd May 2019 1:36pm
Behind a black cover that's hard to see Whistle Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #513995 2nd May 2019 3:43pm
There is another (maxi fuses) on the firewall in the engine compartment (somewhere behind the battery) .
Post #513997 2nd May 2019 3:52pm
Tight777
So I assume the battery needs to come out to access it?
Post #514027 2nd May 2019 7:49pm
I would guess the "ignition relay" is in the big black box with 10 screws .
Post #514030 2nd May 2019 8:17pm
Tight777
"I would guess the "ignition relay" is in the big black box with 10 screws"
I can't see it or find a diagram of what is in there, nothing on underside of lid.
Post #514070 3rd May 2019 8:52am
GraemeS
Australia
I expect it to be in the passenger compartment fuse panel where it is in the RRS of the same era.
Post #514081 3rd May 2019 9:57am
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi there,
the central junction box is behind the glove-box (and a pain in the donkey to get to/play with due to humans not having three elbows) and that is where you will find the ignition relay.
good luck! 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #514085 3rd May 2019 10:29am
Tight777
Looks like a different car to mine, and LHD.
My fuse box in the glove box is, unless that removes and you access behind it?
Post #514511 7th May 2019 8:26am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
No Sir the diagram above is 2010-2012 (assuming it's L322)-- you have the front fuse box in your picture Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #514513 7th May 2019 8:54am
To remove glovebox .
Post #514549 7th May 2019 1:53pm
