Home > Technical (L322) > Terrain response on the road?
Anvil
Hi All,
I sort of asked this question in another post, but I don't think I was clear! Confused So I'll re-phrase. Do the later (post 07) cars with the rotary terrain response dial actually perform any differently on the road to those with the older two-switch system? I'm unlikely to be doing much off roading if I'm honest. Is handling much improved?
I'm looking at 4.2 SC models but am guessing same rules would apply for all?
Thanks in advance,
Si.
Post #514771 9th May 2019 1:40pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Using Sand mode makes the throttle response faster and allows more revs without Traction Control cutting in, but apart from that I've not noticed any other effects.
If you've got the Adaptive dampers on a later facelift L322, I'm not sure if they change mode with any of the Terrain Response settings Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #514775 9th May 2019 2:25pm
CS
There have been threads on here that said that terrain response 2 puts the car into grass gravel snow automatically if the temperature is low enough, even of on a dry road, so slowing throttle response. If wanting normal response one had to choose 'road' manually.
Based on a situation when I was struggling to get up a grassy/muddy clay slope in a 322, the grass gravel snow setting was more effective in solving the problem than road. GGS is notably gentler in take-off. Only Range Rovers since 1988
Post #514786 9th May 2019 3:27pm
mjdronfield
Mine has never done anything without me changing it manually.
Not that I’ve seen anyway, and I would have noticed as throttle response changes quite a bit.
In normal though, can’t imagine any differences on road between years, well, not due to terrain response anyway....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #514795 9th May 2019 5:23pm
Anvil
Thanks for the responses folks. if anyone has driven both on the road (I'm sure it makes a difference off) I'd love to know your thoughts! Cheers.
Si.
Post #514829 9th May 2019 10:25pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Really interesting topic.
So.... what we're saying is, leave it in Sand mode and sport? Laughing
Just kidding Formerly happymadison1978
Post #514834 9th May 2019 10:52pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
CS wrote:
There have been threads on here that said that terrain response 2 puts the car into grass gravel snow automatically if the temperature is low enough, even of on a dry road...
yep below 5C and with TR2 you go into G/G/S - the Censored of it though is that it doesn't warn you on the dashboard that it has done it..
A simple idea like that would have saved me a trip to the dealership to run diagnostics as to why my car had suddenly become so sluggish!! Shocked Evil or Very Mad Rolling with laughter
Post #514848 10th May 2019 9:27am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Never had a need to use it Sad
Post #514918 10th May 2019 8:09pm
stu1
**Post in error**
Post #514919 10th May 2019 8:11pm
