Home > Technical (L322) > 4.4 ajv8 vs 4.2
Danwilderspin
4.4 ajv8 vs 4.2
Hi all had my heart set on a 4.2 with updated interior but struggling to find everything I want. I have now found a 4.4 ajv8 but know nothing about this engine it seems like a ghost! Most importantly how does it sound compared to the s/c and Bmw v8? Fuel wise is it much better than the s/c? Anything to watch out for? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #514605 7th May 2019 8:19pm
Danwilderspin
Bump Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #514732 8th May 2019 10:48pm
Dolphinboy
The jag 4.4 is a good engine but not so good for lpg. I would go for the 4.2 SC for its thrills and good reputation for resilience.
Fuel wise the 4.2 is thirstier - my 4.4 gets c. 20 ish mpg but with lpg gets nearer 30. An SC will prob give up to 18-20 depending on driving style.
Post #514733 8th May 2019 11:47pm
Danwilderspin
Is your 4.4 on LPG though? I think I am going to go with the 4.2 on lpg. After a lot of research the main problems seem to be running off a single hole tank (so it runs lean) and things get too hot and people don’t use valve saver. Both of which I will do. I also will get it converted myself so hoping I should get many miles before lpg issues! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #514833 9th May 2019 10:35pm
TugRR
I owned a 4.4 AJV8 for 18 mths - superb, 300bhp with decent economy. Only problem I had was a MAF unit costing £150.
The engine was (probably) the most common in the L322 of that era & known as the ROW (Rest Of the World) motor, but is rare here. It's an unsung hero in my eyes.
I used to get 18 ish mpg with upto 23 mpg on a run - try that in an S/C ! Plus, there are lower tax bracket cars out there . . .
My only observation is it's not what you'd perhaps expect in terms of torque delivery, being available higher up the rev range. That being said, for hilly areas just using the gearbox in manual more it was fine which I preferred anyway.
Thumbs Up Where do you go after one of these . . . ?
Post #514907 10th May 2019 7:19pm
Dano0404
I've got a 4.2 sc on lpg with valve saver and get 13.5 mpg with just normal running around. I'm not really heavy on the throttle either. 2007 sc
Post #514913 10th May 2019 7:46pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
I'm not sure there's vast mpg differences between the various petrol engines, especially the 4.2 and 5.0 S/C - the real impact is how and where you drive them?
I average 22-23mpg in my 5.0 S/C with a mix of crossing right through central London and then doing the motorways down to Dorset. If I just drive round Central London in stop/start traffic, it plummets to 10-12 mpg, or if I just drive down a motorway with the cruise on ~70mph I've seen it nudge up to 25-26mpg.
So not really sure the 4.4 AJV8 engine is that much more efficient to be honest, although with any S/C RR, if you are worried about the fuel, then it's the wrong vehicle to buy!
Post #514935 10th May 2019 10:14pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Yes, avoid stop start traffic like the plague in an SC. For comparison, we previously had the 4.4 BMW engine and the MPG compared to our 4.2 is the same. Not a direct comparison to the AJ4.4 but I would be surprised if the difference was noticeable.
Post #514938 10th May 2019 10:28pm
Danwilderspin
Great advise guys - I’ve had the 4.4 bmw for 3 yrs on lpg and happy(ish) with those fuel bills so if I go 4.2 on lpg it will be there or there about a and 4.4aj marginally better? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #514981 11th May 2019 2:25pm
stu1
Sounds about right, but don't forget the 4.2 is super charged, so I'm guessing that at least initially your MPG won't be anywhere near the normally aspirated Smile
Post #514997 11th May 2019 7:40pm
Danwilderspin
Yea tbh my wife drives the more local trips in it during the week so the s/c will barely be used and I use just on long runs so hoping it will bed In Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #515014 11th May 2019 9:16pm
Danwilderspin
Just went to look at eBay item no eBay Item No. 123776619028
What a joke and waste of time if anyone else thinks it’s a good deal it’s not. On the phone said it was all fine.
Got there cold start misfiring consistently at idle - tried to say because there wasn’t much petrol so i revved it and it’s fine higher up the range and he then said it sounds like it just needs a coil pack... then eml was on too I left it as it stank of vsr issues. It would potentially be a good buy if you could knock them down if you did the heads yourself as the underneath by some miracle had next to no rot!
The car was the polar opposite of the others I’ve seen - rot but good drive train. Btw I appreciate it was cheap and my budget is a fair bit higher but as I was in the area I thought I’d look! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #516519 26th May 2019 12:23am
stu1
Bad luck.
It is pretty cheap though, but if the ad was honest it could've saved you a trip! (or at least given you an idea of what was needed before you went to look at it)
Post #516650 27th May 2019 10:40am
