![]() | Home > Technical (L322) > 4.4 ajv8 vs 4.2 |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2301
Bump Current stable:
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
The jag 4.4 is a good engine but not so good for lpg. I would go for the 4.2 SC for its thrills and good reputation for resilience.
Is your 4.4 on LPG though? I think I am going to go with the 4.2 on lpg. After a lot of research the main problems seem to be running off a single hole tank (so it runs lean) and things get too hot and people don’t use valve saver. Both of which I will do. I also will get it converted myself so hoping I should get many miles before lpg issues! Current stable:
| TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201
I owned a 4.4 AJV8 for 18 mths - superb, 300bhp with decent economy. Only problem I had was a MAF unit costing £150.
| Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44
I've got a 4.2 sc on lpg with valve saver and get 13.5 mpg with just normal running around. I'm not really heavy on the throttle either. 2007 sc |
| paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358
I'm not sure there's vast mpg differences between the various petrol engines, especially the 4.2 and 5.0 S/C - the real impact is how and where you drive them?
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
Yes, avoid stop start traffic like the plague in an SC. For comparison, we previously had the 4.4 BMW engine and the MPG compared to our 4.2 is the same. Not a direct comparison to the AJ4.4 but I would be surprised if the difference was noticeable. |
Great advise guys - I’ve had the 4.4 bmw for 3 yrs on lpg and happy(ish) with those fuel bills so if I go 4.2 on lpg it will be there or there about a and 4.4aj marginally better? Current stable:
Sounds about right, but don't forget the 4.2 is super charged, so I'm guessing that at least initially your MPG won't be anywhere near the normally aspirated |
Yea tbh my wife drives the more local trips in it during the week so the s/c will barely be used and I use just on long runs so hoping it will bed In Current stable:
Just went to look at eBay item no eBay Item No. 123776619028
Bad luck.
| All times are GMT |
