Home > In Car Electronics (L322) > Reversing Camera
Brian Considine
Reversing Camera
New here & to RR ownership.
I've tried searching the threads & tried the search facility to no avail.
I'd like to fit a reversing camera (& perminatly disable the reversing sensors) - is there a handy connection anywhere in the rear to do so please ? I'd like it to come on when reversing automatically on the front screen.
TIA, Brian
Post #515075 12th May 2019 1:00pm
Weegie
Welcome Thumbs Up
You haven't stated which vehicle. You could update your sign-in.
Firstly any aftermarket reversing camera MUST be NTSC not PAL or PAL/NTSC.
There is no convenient way at the rear of the vehicle to plug it in. You need to access the rear of the head unit to make the connection. You will probably also need a FARCLA cable to be compatible with the socket on the back of the head unit. The shop on here can supply one. They aren't expensive.
Once fitted it is then a question of splicing into the reverse light power (or other suitable place) so that the camera comes on automatically when reverse is selected.
That was how I did it on my TD6 when I had it. John
GAP iiD BT-Sold
Post #515079 12th May 2019 1:23pm
Brian Considine
Thanks for the welcome & information.
Rather than run a cable from rear to front then I may be better off getting a wireless camera then ? Interesting about NTSC.
The RR is a 2003 Vogue (it should be on my profile).
Post #515081 12th May 2019 1:33pm
Weegie
Wireless would still need access to the rear of the head unit.
Your vehicle isn't showing. Sad John
GAP iiD BT-Sold
Post #515085 12th May 2019 1:59pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
If it is a 2003 car with the BMW based system then you need to connect the camera to the radio unit in the boot rather than the back of the screen in a later model.
I can’t remember but the BMW units may be PAL rather than NTSC.
Post #515091 12th May 2019 3:51pm
Weegie
Interesting. Thanks for the heads up. I was working on the later model. Thumbs Up John
GAP iiD BT-Sold
Post #515093 12th May 2019 3:55pm
Jamiehol
I can’t find the guide I used when doing mine, but there is a brief guide on bimmernav.com
Post #515094 12th May 2019 4:02pm
Brian Considine
I think it has the BMW system - that will make it easier I think.
I'll have another look in the boot - I'am assuming I'm looking for a yellow phone/RCA ? 2003 Range Rover Vogue TD6
Post #515121 12th May 2019 7:44pm
Jamiehol
The connector isn’t there as standard you either buy a loom that that gives you the RCA, or get the individual wires to plug into the radio multi plug from a BMW Dealer.
Post #515132 12th May 2019 9:09pm
Balloonengineer
Hi
See my post here on how I did it. It's not difficult
https://www.fullfatrr.com/forum/topic44895.html
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #515164 13th May 2019 8:59am
Jamiehol
Sadly that isn’t any good for the OP as that is the later touchscreen system and not the BMW based one.
Post #515229 13th May 2019 6:33pm
