![]() | Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I may have the same...very small weep over time. Defo not oil cooler in the "V" or the pipe O rings as that's been done and is as dry as a bone in there. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
NS (passenger) side wheel?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Yes NS - Passenger side.
Yep, diff casing looks wet....
Booking it in for an inspection. Needs the engine bottom covers removing for a better look. It appears to be somewhere above and forwards of the front diff....and it’s defo engine oil |
Does sound similar to mine DrRob.
I'll keep you posted........ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I had oil leak on mine a whale back and it was a plug that screws in the top of the oil pump. I losend the plug, applied some silicon, tighten it back in and all good.
No. 3 on this diagram Nino?
yes. 2012 TDV8 Black Edition
Nothing obvious could be seen by the mechanic who I trust 100% Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Funny isn't, I have a solid search on mine and - couldn't find it.
I’m booked into SLR Automotive (Haslemere) in 2 weeks time for another investigation as I still have the odd drive drip |
Nothing obvious on inspection. Full steam clean and return inspection in 2 weeks. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
