Home > Maintenance & Mods (L322) > 4.4TDV8 - Oil leak from front / low / right side of engine
Page 3 of 4 <1234>
DrRob
I may have the same...very small weep over time. Defo not oil cooler in the "V" or the pipe O rings as that's been done and is as dry as a bone in there. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515599 17th May 2019 1:13pm
GGDR
If you pop your wheel off, use an axle stand or two because you need to get your head right in the wheel well.
If you have a GoPro or similar it might even get you visibility deeper in that pocket of the engine bay.
. Cheers, Greg
Post #515601 17th May 2019 1:28pm
DrRob
NS (passenger) side wheel?
What do you suspect it is? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515602 17th May 2019 1:29pm
GGDR
Yes NS - Passenger side.
Really not sure, it seems it might be dripping onto the front diff.
. Cheers, Greg
Post #515605 17th May 2019 1:35pm
DrRob
Yep, diff casing looks wet....
I'll borrow a digital camera boroscope..... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515606 17th May 2019 1:36pm
DrRob
Booking it in for an inspection. Needs the engine bottom covers removing for a better look. It appears to be somewhere above and forwards of the front diff....and it’s defo engine oil Rolling Eyes
Top of diff bone dry, bottom a bit of oil on it. Block behind looks a little moist too..... Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516198 22nd May 2019 5:38pm
GGDR
Does sound similar to mine DrRob.
Block a bit wet behind: my theory is that wind pressure pushes it back.
. Cheers, Greg
Post #516457 24th May 2019 10:06pm
DrRob
I'll keep you posted........ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516762 28th May 2019 12:06pm
nino_nino
I had oil leak on mine a whale back and it was a plug that screws in the top of the oil pump. I losend the plug, applied some silicon, tighten it back in and all good.
Nino, Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #516766 28th May 2019 12:56pm
GGDR
No. 3 on this diagram Nino?
 Cheers, Greg
Post #516797 28th May 2019 8:54pm
nino_nino
yes. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #516835 29th May 2019 8:50am
DrRob
Nothing obvious could be seen by the mechanic who I trust 100% Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516980 30th May 2019 8:11pm
GGDR
Funny isn't, I have a solid search on mine and - couldn't find it.
For a big car with a big engine bay, there's so much stuff packed in there you can't clearly see either side of the engine.
. Cheers, Greg
Post #516986 30th May 2019 9:25pm
DrRob
I’m booked into SLR Automotive (Haslemere) in 2 weeks time for another investigation as I still have the odd drive drip Whistle
Will report back on findings.
Chap are ex LR trained https://www.slr-automotive.co.uk/about-slr.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #528757 22nd Sep 2019 9:12am
DrRob
Nothing obvious on inspection. Full steam clean and return inspection in 2 weeks. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #530321 8th Oct 2019 5:17pm
Page 3 of 4 <1234>
