![]() | Home > Maintenance & Mods (L405) > Seat Arm Rest Fix Anyone? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8032 ![]() ![]() ![]() |
Tension ?
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Sorry, what Im trying to describe is the mechanical motion you can feel if you had the rest upright out of the way then pull it down to use as an arm rest, its gone floppy and just drops down.
I'll have to test mine - I never really move it - but I guess if it's different to the passenger side then there's a problem |
Passenger side has a nice light pressure feel to gently lower it down but doesnt continue to fall if you take your hand off it, mine just flops to the low point thats its set to, no or very little resistance |
If you can't fix it, then these may be worth a punt to butcher..... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
This might help as to how to access it.
I was looking at those seats earlier strangely enough, will look around the rest over the weekend see if it becomes clear how to remove it? |
Yeah possibly too much work just to change an arm rest |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
Hopefully this might help sir... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3835 ![]() ![]() ![]() |
This is L322 info on armrests, but it might be similar to L405?
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 ![]() ![]() ![]() |
Happened on our discovery. Just tighten the bolt up that holds it on the seat. |
The T27 was rock solid so think the mechanism inside must be broken and its made the arm rest a bit floppy, will live with it for now
Carlos, if you have the necessaries? Remove the securing screw and the armrest simply pulls off... If you look at this video
