![]() | Home > Technical (L322) > Towing socket broken |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
I think if you lift the spare wheel cover you may find the cables come into the wheelwell on the nearside rear bulkhead, through a grommet lined hole. If it's a factory set up there should be a grey connector on the nearside whch should allow you to remove the cables/plugs. Seeing as yours has a T and S set up you may have a slightly different arrangement, perhaps two cables from the sockets into a joiner then the socket.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Any idea how to bung up the hole if I remove the wires? Regards
I think the hole is rectangular, so a rubber grommet should work. You may be able to get one from Dan at Duckworths or if you measure it carefully, then eBay may be the place. Alternatively, P F Jones, Britpart, Eurocarparts. Cheers
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Would make much more sense to repair the spring/s or replace the socket.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Tape it shut with gorilla tape?
So after playing with it , I think That the spring is not replaceable because the pin that goes through the lid doesn’t knock out.
Ditch them both and replace it with a single 13pin version. I fitted mine in minutes. Comes with a rubber grommet to keep boot dry. Plug and play on a 2011 model. Happy to assist you to fit it |
Dr rob I will take you up on that offer if that’s ok?
No experience on the grommet but Dan will have some I reckon.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Hi, I have just come in from replacing my 13 pin socket, I went on the internet and found a wiring diagram with the colour code. do not use that one as it will not match the wiring colours that are on the FF what I did was to dig out the silicon on the old socket to expose the wires and cut them leaving about 3-5 mm and then follow the wires as they go into the socket test before fitting to the car then fill with silicon and screw back with some anti-seize grease on the screws,
I think the 13 pin have more functionality than standard 7 pin wiring will allow Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
A Range Rover without a tow bar looks undressed to me. |
DR ROB, have you got pics of what you did? i think i may go this route as i dont seem to be getting anywhere with regards to removing them completley and making sure the boot is re grommeted lol, Or i guess the other way is to replace the socket like for like from land rover? Still not sure where the wires go to and get connected? Regards Daz ------------------------- 2011 (61plate) 4.4 tdv8 sumatra black previous cars e46 m3 e53 x5 |
