Home > Technical (L322) > Towing socket broken
Page 1 of 3 123>
dazza1983
Anyone know how to fix this??
Springs broken on the cap so now it won’t stay shut, would like to remove the electrics if possible as I will never tow. had a quick look underneath car and see the wires go into something but don’t know where.
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #515735 18th May 2019 5:58pm
rjff
I think if you lift the spare wheel cover you may find the cables come into the wheelwell on the nearside rear bulkhead, through a grommet lined hole. If it's a factory set up there should be a grey connector on the nearside whch should allow you to remove the cables/plugs. Seeing as yours has a T and S set up you may have a slightly different arrangement, perhaps two cables from the sockets into a joiner then the socket.
You could also pick up a socket and replace it for £2 or £3. Cheers
Richard
Gap IIDBT
Post #515749 18th May 2019 8:06pm
dazza1983
Any idea how to bung up the hole if I remove the wires? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515799 19th May 2019 10:10am
rjff
I think the hole is rectangular, so a rubber grommet should work. You may be able to get one from Dan at Duckworths or if you measure it carefully, then eBay may be the place. Alternatively, P F Jones, Britpart, Eurocarparts. Cheers
Richard
Gap IIDBT
Post #515801 19th May 2019 10:29am
Would make much more sense to repair the spring/s or replace the socket.
IMHO you will devalue your vehicle by removing everything, and you never know when you might need to tow something... .
Post #515802 19th May 2019 11:08am
rjff
Thumbs Up Joe Cheers
Richard
Gap IIDBT
Post #515813 19th May 2019 12:12pm
DrRob
Tape it shut with gorilla tape?
Or take it to a towing place who should be able to replace the spring....
Keep them on the car. Useful to charge battery with an adaptor off the forum shop Thumbs Up
https://www.disco3.co.uk/shop/tow-electric...c-p45.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515814 19th May 2019 12:30pm
dazza1983
So after playing with it , I think That the spring is not replaceable because the pin that goes through the lid doesn’t knock out.
You can’t replace the socket because Land Rover mould the wires to the inside of the plastic so only thing you could do is replace with a Land Rover socket by the looks of it. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515856 19th May 2019 6:41pm
DrRob
Ditch them both and replace it with a single 13pin version. I fitted mine in minutes. Comes with a rubber grommet to keep boot dry. Plug and play on a 2011 model. Happy to assist you to fit it Thumbs Up
It will also look more discreet than 2 sockets
I top up my battery now and again through it via an adaptor and a Ctek battery conditioner.
Dan at Duckworths is your man Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515860 19th May 2019 7:33pm
dazza1983
Dr rob I will take you up on that offer if that’s ok?
To be honest I would like them gone they are ugly lol
But if I have to fit a single 13 pin thing then I will lol.
Do you have any experience with the groomer that would replace the wires at all buddy? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515861 19th May 2019 7:36pm
DrRob
No experience on the grommet but Dan will have some I reckon.
I replaced an old 7 pin with a new 13 pin so blanking grommet was not in place.
I’d bung a 13 on if I were you and then you have the option to top up battery Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515862 19th May 2019 7:37pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, I have just come in from replacing my 13 pin socket, I went on the internet and found a wiring diagram with the colour code. do not use that one as it will not match the wiring colours that are on the FF what I did was to dig out the silicon on the old socket to expose the wires and cut them leaving about 3-5 mm and then follow the wires as they go into the socket test before fitting to the car then fill with silicon and screw back with some anti-seize grease on the screws,
Hope this helps with your 7 pin?
Forgot to say it cost me £6 instead of £118 from LR
Post #515865 19th May 2019 7:57pm
DrRob
I think the 13 pin have more functionality than standard 7 pin wiring will allow Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #515873 19th May 2019 9:06pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
A Range Rover without a tow bar looks undressed to me.
Post #515878 19th May 2019 9:22pm
dazza1983
DR ROB,
have you got pics of what you did? i think i may go this route as i dont seem to be getting anywhere with regards to removing them completley and making sure the boot is re grommeted lol,
Or i guess the other way is to replace the socket like for like from land rover?
Still not sure where the wires go to and get connected? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515912 20th May 2019 10:29am
Page 1 of 3 123>
