![]() | Home > Technical (L322) > Towing socket broken |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
If you don't intend to tow and the flapping cap is annoying you, put a bead of silicone sealant round it and stick it like that. Don't use glue in case you or someone else finds a need to tow with it.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
ive actually just done this lol,
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
7 stg on ebay for just the 7 pin socket and 75 stg for the socket including wiring |
7 stg dolph? Regards
eBay Item No. 280630189934 is the item number Daz i was outside the school waiting for the kids reading your post and had a search. 2015 4.4 AB
dolph
Go outside and get some fresh air to clear your head. ![]() 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
I did see you post that in your thread Daz but i thought at that price maybe worth a look. 2015 4.4 AB
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
If you are really that bothered I have a spare pre-wired 7-pin socket that you can have for the price of the postage.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Or remove it completely and gorilla tape the hole instead of the grommet. It’s tucked well out of the way so should be minimal spray that gets there
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 133 ![]() ![]() ![]() |
Looks like you could carefully file away the peened over end of the pin until it is flush with the plastic then the pin will push out. Do the same with a cheap new socket to get the new spring, then replace spring and cover on old socket and use a small bolt and nut in place of the pin. Stuart (Also in Southampton, SO18 area if that is anywhere near you) |
Not a bad idea stu |
SO im getting more confused everytime i look at this car lol,
Daz
