Home > Technical (L322) > Towing socket broken
Page 2 of 3 <123>
dazza1983
Well this is turning out to be a bloomin knightmare lol
All because the bloomin spring broke on the cap
So it seems you cant just replace the spring and cap because the pin that goes through the cap is peeled over at the ends so it wont knock out
you cant buy just one socket from land rover you have to buy the loom which comes with both sockets... yeah thats expensive
You cant take out the old wire and buy a new housing because the wires look glued / moulded / silliconed in? Or maybe someone has been there before and did this?? Anyone know if you can actually remove the wires from the rear of the sockets?
And then i thought ok.. ill remove them then seen as i dont tow, oh well if i do that then the grommett where the wires push through will be left with a hole in it and the local dealer cant find a new grommet listed to replace it
really why so difficult for such a stupid problem??? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #515948 20th May 2019 2:42pm
Weegie
If you don't intend to tow and the flapping cap is annoying you, put a bead of silicone sealant round it and stick it like that. Don't use glue in case you or someone else finds a need to tow with it.
A fine bead will be easily concealed. John
GAP iiD BT-Sold
Post #515949 20th May 2019 2:50pm
dazza1983
ive actually just done this lol,
I just cant belive a silly problem can be so difficult to sort properly , in my head all ive done is bodged it if you know what i mean lol Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515951 20th May 2019 3:05pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
7 stg on ebay for just the 7 pin socket and 75 stg for the socket including wiring Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #515952 20th May 2019 3:07pm
dazza1983
7 stg dolph? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515953 20th May 2019 3:07pm
dolph34
eBay Item No. 280630189934 is the item number Daz i was outside the school waiting for the kids reading your post and had a search. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #515958 20th May 2019 3:32pm
dazza1983
dolph
the trouble is buddy you cant get the wires out from the origional because they are moulded / glued / silliconed in?? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #515959 20th May 2019 3:36pm
Weegie
Go outside and get some fresh air to clear your head. Laughing John
GAP iiD BT-Sold
Post #515960 20th May 2019 3:39pm
dolph34
I did see you post that in your thread Daz but i thought at that price maybe worth a look. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #515961 20th May 2019 3:40pm
Brian Considine
If you are really that bothered I have a spare pre-wired 7-pin socket that you can have for the price of the postage.
All you would have to do is reconnect it where the existing one connects or splice it to the existing cable in the boot. 2003 Range Rover Vogue TD6
Post #515970 20th May 2019 5:06pm
DrRob
Or remove it completely and gorilla tape the hole instead of the grommet. It’s tucked well out of the way so should be minimal spray that gets there
Bring it round to my place and we can go through it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #515972 20th May 2019 5:14pm
stuart_2006
Looks like you could carefully file away the peened over end of the pin until it is flush with the plastic then the pin will push out. Do the same with a cheap new socket to get the new spring, then replace spring and cover on old socket and use a small bolt and nut in place of the pin.
Stuart
(Also in Southampton, SO18 area if that is anywhere near you)
Post #516011 20th May 2019 9:40pm
dazza1983
Not a bad idea stu Thumbs Up Thumbs Up Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #516069 21st May 2019 10:29am
dazza1983
SO im getting more confused everytime i look at this car lol,
I was toying with the idea of replacing both the towing sockets for new ones,
so naturally as one does, i was searching the internet for prices and looking at pictures etc, then tonight i looked inside the boot and found that my wiring loom looks slightly different to the rest of the towing electrics ive seen on the net even genuine ones for instance if you search for l322 towing electrics / sockets most of these come with a loom and like 3-4 plugs and the earthing wires etc,
Well it looks like i can just unplug this big grey delphi socket and pull my sockets straight out which is fine but it begs the question what do i buy to replace it???
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #516116 21st May 2019 8:24pm
DrRob
Daz
Yours is 100% standard. Mine has the exact same plug. Replace it with a Genuine 13pin one and then you can top up the battery with an adaptor and ctek. Handy to have Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #516121 21st May 2019 8:49pm
Page 2 of 3 <123>
