Home > Duckworth Parts > l405 grille |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Your profile suggests you have a 14MY sir! If you do, a 2018 grille will not fit! |
21st May 2019 6:57pm |
Yes sir it will... |
21st May 2019 9:36pm |
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 135 |
Profile updated ! |
21st May 2019 10:26pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
Do you have a picture of the grille you require, not known as a Shadow grille on the catalogue You can paypal direct using - www.paypal.me/duckworthparts
22nd May 2019 9:03am |
22nd May 2019 2:05pm |
£225.00 posted You can paypal direct using - www.paypal.me/duckworthparts
22nd May 2019 2:58pm |
I think the OP wants a Narvick Black grille Dan |
22nd May 2019 6:16pm |
What are you trying today achieve sir? Do you wish to unplug them for use/permanently? |
26th May 2019 5:40pm |
Yes, BUT! You will need to remove and refit the PDC plastic holders... Im trying to remember weather it was front and rear PDC holders or just the fronts? 18MY> have a different PDC sensor but the painted bit you see is exactly the same size as the 15MY... The PDC holders are sonic welded so can be pulled off and glued back on using PU glue or alike |
26th May 2019 9:10pm |
The easy answer John is, you will have everything you need between the two bumpers sir...
27th May 2019 1:47am |
Your very welcome sir |
27th May 2019 10:11am |
