![]() | Home > Duckworth Parts > l405 grille |
Your profile suggests you have a 14MY sir! If you do, a 2018 grille will not fit! |
Yes sir it will... |
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 141 ![]() ![]() |
Profile updated ! |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
Do you have a picture of the grille you require, not known as a Shadow grille on the catalogue You can paypal direct using - www.paypal.me/duckworthparts
£225.00 posted You can paypal direct using - www.paypal.me/duckworthparts
I think the OP wants a Narvick Black grille Dan |
What are you trying today achieve sir? Do you wish to unplug them for use/permanently? |
Yes, BUT! You will need to remove and refit the PDC plastic holders... Im trying to remember weather it was front and rear PDC holders or just the fronts? 18MY> have a different PDC sensor but the painted bit you see is exactly the same size as the 15MY... The PDC holders are sonic welded so can be pulled off and glued back on using PU glue or alike |
The easy answer John is, you will have everything you need between the two bumpers sir...
Your very welcome sir |
