Home > Technical (L405) > L405 FBH Telestart Receiver Fob Pairing - Solved
Page 3 of 5 <12345>
PLOG
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Thanks all. Great help. Thumbs Up
I too have now paired successfully. Really good to get into a warm car this morning after my night shift.
Mine is a 2013 model, and if it helps anyone in the future reading this thread, I can confirm it’s the same fuse JCW pulled in his 2014.
Thanks again everyone.
Post #499304 21st Dec 2018 9:28am
Ent
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
JCW wrote:
I too have now successfully paired my fob Thumbs Up
Mines a MY14 and it was fuse 1 (5a) in the fuse box behind the glovebox, method as already described. Paired first time, my fob is exactly per the one pictured above.
So although there is a 20a fuse in the rear luggage compartment area (described as Fuel Fired Booster Heater in the handbook) I presume removing it doesn't disable power to the FBH receiver, as required for the pairing procedure.
New to the L405 and haven’t got the book with me, how do I access the fuse panel in the front passenger footwell?
Post #516171 22nd May 2019 1:45pm
aljo
United Kingdom 2019 Range Rover Vogue SE 2.0 PHEV Santorini Black
Pull the glove box down ( unhinge the lock tabs) and all will be revealed 👍👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #516179 22nd May 2019 2:28pm
Ent
I don’t know where the unhinged tabs are and I don’t want to force anything
Post #516186 22nd May 2019 3:10pm
aljo
ent pul the glovebox down and look inside for the 2 stop tabs on either side and just press them sideways into the middle and will lower the glove box fully Thumbs Up unhinge was the wrong choice of words lol
ps have you progressed from a D4 to the posh side ? lol
recognise your name from disco3 Thumbs Up Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #516234 22nd May 2019 9:55pm
Ent
Yes mate Thumbs Up
I had a lump of foam covering the fuse panel when I managed to drop the lower glove box
Can’t get my Eberspacher remote to pair yet. I’ll have another go tomorrow.
Post #516249 22nd May 2019 11:14pm
Andy
If anyone needs a new style fob I have one for sale. I bought it thinking it would pair with my L322 system.
£22 delivered. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #535223 23rd Nov 2019 1:47pm
aljo
Pm sent Andy 👍 Last night I lay in bed looking up at the stars in the sky and I thought to myself, where,s the f**king ceiling!!
Post #535241 23rd Nov 2019 4:21pm
Ross Brown
United Kingdom 2013 Range Rover Autobiography SDV6 Havana
Hi Guys.
Sorry to bring this thread up again. Rolling Eyes
I have recently bought a 2013 L405 Autobiography which does have on the build sheet it has remote timed fuel burning heater etc.
Anyway I haven't got the vehicle yet it will be Tuesday when I pick her up.
I asked when I went to see it where is the remote for the diesel heater and he didn't have one so I guess the owner kept it.
But hey on a plus he did have a remote spare at his site and said he would leave it in the vehicle but I would just need to get it programmed.
I understand how to program it thanks to you brilliant guys but not sure if the remote is suitable to my vehicle?
Here is the picture of it.
Is this compatible with the L405 or do I need the newer style?
Any help would be appreciated.
Thanks guys Thumbs Up
Ross.
Post #568100 27th Sep 2020 8:02am
Justin017
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
Hi all,
Sorry to revive this thread. I've got a 4.4 V8 diesel (2014) with the FBH. I know it works because I've tried the timed climate setting on the screen.
I've got a fob from a 2020 Autobiography (its the T91r with the heater symbol instead of 'off').
My questions are:
On a 2014 Autobiography is it definitely the 20A fuse in the boot?
Just because the car has FBH does it definitely have the remote functionality?
Is the T91r compatible?
The fob just flashes about 8 or so times when I press on or off, I can't seem to get the fob to want to pair to a new receiver.
Post #587405 14th Mar 2021 9:51am
JCW
Likely to be fuse 1 (5amp) in the fuse box behind the glovebox (based on my experience of an MY14 L405).
Post #587406 14th Mar 2021 10:01am
Justin017
Hiya,
I’ve also tried that one. The symbol for that fuse suggests it’s some sort of vehicle receiver as it shows a car with air waves going through it but I still get the same result there. If a fob is already paired with another vehicle is it the same procedure do you know?
Post #587407 14th Mar 2021 10:06am
JCW
It’s the fuse for the Telestart fbh receiver, sounds like that’s the right fuse.
Yes same procedure - may be the fob you’re using in which case, not sure if an MY20 will be compatible, can you add a photo? Should look like this
Post #587408 14th Mar 2021 10:16am
Justin017
Sure no problem. Photo attached.
I know the fob works because it was working on the 2020 car it came from for sure.
I’ve even tried taking both fuses out and same result
Post #587409 14th Mar 2021 10:19am
JCW
That looks like an older MY fob to me.
Post #587410 14th Mar 2021 10:22am
Page 3 of 5 <12345>
