![]() | Home > Technical (L322) > Accessing EPB service Mode |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
You just need the handbrake off. Turn it off then hold down the button as if turning it off and then turn the ignition key off. That should keep it off. There is a procedure to bed it in once the discs are replaced too. Current 2007 TDV8 Vogue Buckingham Blue |
KGB035 Member Since: 03 Mar 2018 Location: Leighton Buzzard Posts: 3 ![]() ![]() ![]() |
Thanks kbald. This something you've done and it worked fine? Guess the bedding in procedure will be on here somewhere as well. |
Yep exactly what I did with mine. Mines a 2007 but still same electronic handbrake I believe. The bedding in process is indeed on here I'm sure I posted it myself. Just try the search die disc change or handbrake bedding in process and it should come up.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2712 ![]() ![]() ![]() |
I did the bedding in manually as per a thread on here, took a while but I got there. |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I did it without IID or putting handbrake in service mode. Bedding in process worked fine too after a couple of attempts. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
