Home > Maintenance & Mods (L322) > K and N air filter
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
K and N air filter
Hi has anyone got opinion on KandN on 4.2 advice please pros and cons appreciated
Post #517710 7th Jun 2019 6:50pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I have read just as many reviews that say they're a waste of money as I have that say they add bhp and torque.......you pays your money etc.
Having said that I have put one in Mrs B's Cooper S Laughing Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #517712 7th Jun 2019 7:22pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
I did have K & N filters on my 3.9 classic with re-jetted carbs (engine / gearbox was installed by specialist so had a choice carbs or injection). I didn't have any problems, cleaned and re-oiled them as per instructions.
However, I personally would not fit them to a engine that has a MAF (as most do now) having heard stories that, if they are over oiled the oil mist can contaminate the MAF and screw up the mixture settings,
Some people do run them dry which I think defeats the whole purpose of protecting the engine.
If you want to improve performance there are a number of things you can do :-
1/ Remap the engine.
2/ Custom made stainless exhaust with tubular manifolds with different silencers.
3/ Get the supercharger pulley wheel changed for a smaller one = higher rpm = higher inlet manifold pressure
(there are companies that can do this) approx. £500 or you can get a DIY kit.
4/ Replace the pipe between MAF and inlet with 90deg stainless pipe + silicone piping joiners improves airflow.
An old forum member did this and reported a marginal increase in performance (The all Seeing Pie).
Bottom line is, tuning is a money pit you have been warned Laughing .
Post #517720 7th Jun 2019 7:40pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
They work if you have modified the engine enough to benefit the the extra air. On a standard engine its pretty much a waste. You may get marginally better throttle response. Just put a good quality paper one in.
As mentioned, over oiling them wrecks the MAF sensors. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #517727 7th Jun 2019 8:08pm
Strider
This is some tuning posts you might find interesting:-
www.fullfatrr.com/forum/topic19069.html
www.fullfatrr.com/forum/topic15296.html
Post #517747 7th Jun 2019 10:45pm
Our mappers have always said that K&N's don't work on modern RR's... Thumbs Up
Post #517749 7th Jun 2019 11:23pm
nino_nino
I had them on mine and could not feel difference one way or another, so I went back to paper elements. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #517755 8th Jun 2019 8:03am
