![]() | Home > My Range Rover > 2010 FFRR conversion with 24's. |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
How weird. Just reading that post you posted!! Does the piece just pull off? |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
I've never tried, but I'm guessing not. It looks like a different trim piece altogether. Only the purists will notice, so I wouldn't worry! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Trouble is, now i've seen it without, i like it!! |
and front and rear black letterring. removed rear LR badge too!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
you've been busy nick.. |
Done a few bits. Done most of LED interior light conversion but awaiting a few extra LEDs. Will post pics/process once completed if anyone interested.
look forward to the pics.. |
Have had them reset previoulsy but this was prior to changing tyres and since doing this had got alot better?!! (until today)
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
Nick, what message do you get on the air suspension fault? There s a clip on YouTube by Powerfuluk on how to reset the Air Suspension Inactive Warning.
I get engine failsafe on dash then all the air suspension hdc abs etc come on. Most common posts from research don't seem to get the engine failsafe first. theres never anything wrong with the engine and never goes into limp mode or anything similar. I've done the left right thing on steering wheel many times to reset. At the moment it clears itself when i turn ignition off. Not been using much last 3 weeks but will be clocking up some miles next week so will see how it goes and book into specialists again if persists. Just want warning lights to go away now and don't care how much it costs (within reason that is!!)
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
nick that looks spot on it looks great in black as well.......if you get a chance could you post what parts are needed for the front end conversion.......also does anyone know if you can put the 2010 bumper with 2006 lights? "RANGEISM WILL NOT BE TOLERATED"
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
I have the 22" and found that after I had changed back to 18" winter tyres that the steering is so much lighter with the smaller wheels.
Google l322.com and you'll find a really good guide to front end conversion. Its fairly simple. Don't think different bumpers will fit with diffrent year lights/ grills etc as all fit into each other but I could be wrong.
