![]() | Home > In Car Electronics (L322) > DIY 3 button key transponder programming & sync-BMW era |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
My RR came with just the one key, and despite only needing the one, it's always good to have spares for an emergency, but then they are expensive from a dealer ( I believe £200 ish each ), and that's too much.
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 402 ![]() ![]() ![]() |
Very impressive..... Well done. Current:
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 936 ![]() ![]() ![]() |
thank you BMG - good to know, as I am on the lookout for 2 new flip keys |
I wasn't aware at the time, but this guide seems to be for only the early BMW era cars, despite later cars still using the same 3 button key. This wont work on later cars. |
mine is 2004 BMW engine EWS3 - I thought it was post 2005/06 cars that used the later EWS4 system where you don't need to get to the EWS under the gear lever to program more keys |
Yep, should be fine. Get the kit mentioned and some chips of eBay and it's all pretty simple to do. |
the youtube video "To add the software" is no longer working, what is the link please |
Look on YouTube, several vids on there on the software install. |
Khalid Member Since: 08 Aug 2024 Location: Doha Posts: 6 ![]() ![]() ![]() |
Excellent Write-up.
If you have lost all the keys I don't think it makes a difference,so long as you can read the EWS box. You can then should be able to create new keys and delete old lost ones. |
Thank you BMG. I thought you need the original key to read the data and connect to EWS box to verify the transponder signal. As long as all the information will come from the EWS, then no need for any key other than to access the car and then remove the center console to get to the EWS box.
I just noticed your car is a later car and not that of the BMW era. The steps and advice I gave only relate to the early BMW engined cars. Sorry for the confusion. |
Thank you for your note. Yes, I do have the 4.2 supercharged engine (JAG) and I loved it.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
Don't waste your time, that write up doesn't work for your vehicle |
