![]() | Home > In Car Electronics (L405) > Car not reporting journeys |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931 ![]() ![]() |
I had the same some months ago but it will right itself and all your journeys should appear. |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
There were two apps in the Apple Store. I installed both. Might be worth trying the other one if you can find it. |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279 ![]() ![]() |
Is this considered as tracking for insurance purposes????? Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Range Rover LSE Member Since: 15 Jul 2012 Location: Preston Posts: 48 ![]() ![]() |
Thanks everyone for your responses, as yet no different, but thanks to Emperor Mong I do now have the more modern app which is version 2. Can only think either LR have an issue or the car has stopped reporting trips for some reason. Everything else works and it always knows where the car is when you fire up the app so not particularly concerned. Range Rover LWB HSE L460
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
Log on with your PC at
Charlie, thanks for the tip to have a look on the web based version, alas it is still not reporting journeys. It has not worked since the 6th of June so I guess it may be a fault with the car as no one else is reporting issues etc. Time for a session with the garage to have a look. Thanks for the help. Range Rover LWB HSE L460
Interesting ? Go on the PC version and go vehicle settings then "remote" and make sure the Journey tab is ticked ? You have got a paid up subscription LOL |
The subscription is in place till 2021 and the journeys switch is in the on “ticked” position. Thanks for suggestions. Range Rover LWB HSE L460
What was the outcome of this ? |
As yet not had time to take the car in, I’ll post up an outcome when we have one. Thought about trading to set up SOTA but I suspect that is not connected as one uses the comms between LR and the car and the other uses the comms through the chip installed in the centre console. Range Rover LWB HSE L460
Booked the car into dealership in another two weeks to progress, however out of interest I checked the app and it appears to have suddenly started reporting journeys from the 5th July. I have yet to check whether the remote start works as that had also failed when it stopped reporting journeys. Range Rover LWB HSE L460
That's what happened with mine, started working again. All LR cars from 1984
