Home > General > 3.6 vs 4.4 TDV8 MPG
grey17
United Kingdom 2010 Range Rover Vogue SE TDV8 Alaska White
appj62 wrote:
I guess you'll be put off by a SC then, whether 4.2 or 5.0 Rolling with laughter
Hi appj62.
I wouldn't go the 4.2 as it's too old but, the 5.0 does have a certain attraction Wink
Never say never!
G
Post #518553 15th Jun 2019 10:17am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
All good points made above. I would just add that work out what kind of journeys you will usr it for.
A remapped 3.6 with egr deleted ( as I have) will do lots of short journeys and not have the DPF issues a 4.4 has.
Which ever one you choose they are a joy to own and drive 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #518565 15th Jun 2019 11:51am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
The turbo drain mod in my view is essential. Oil builds up in the second turbo that only spins up above 2500 rpm which in normal driving can be never! Teh first time you overtake someone or give the beans the scene behind will be something out of a James Bond movie. The smoke can be so dense as to be dangerous. The drain mod gives an independent line back to the sump for each turbo stopping the back pressure building up and oil leaking into the second turbo. Not all 4.4's do it mine definitely did, if you drive round continually like a boy racer no problem, do sedate driving for 10 or 15 miles and then open it up oh dear, not good.
I was sceptical the drain mod would cure it, Green Oval garage knew all about it, assured me it would and it really has sorted it.
AJG BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #518591 15th Jun 2019 5:31pm
kooky_guy
They don't all suffer with this issue though - Mine hasn't had the mod done and never has any problem with smoke. 2010 4.4 TDV8 Vogue SE
Post #519073 20th Jun 2019 9:35am
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
AJGalaxy2012 wrote:
I came to fatty ownership from a Touareg and have just had the pleasure of towing my 2 tonne caravan for the first time. It used less fuel than my Touareg 32 mog plus around town and an amazing 25.2 mpg towing. There’s something special about doing the legal limit with the 2 tonne van on its back at a leisurely 1200 rpm. I can’t speak for the 3.6, I was advised the 4.4 was superior in many ways and I feel this was good advice. If you go the 4.4 route make sure the turbo drain mod has been done or budget £1000 or so to get it done.
Turbo Drain Mod you say?
TM
Post #519362 22nd Jun 2019 11:56pm
TeeMyob
[quote="grey17"]
AJGalaxy2012 wrote:
I came to fatty ownership from a Touareg and have just had the pleasure of towing my 2 tonne caravan for the first time. It used less fuel than my Touare.......
Hi AJGalaxy2012
Thanks mate, thats a good shout regarding the turbo drain and I'mm assuming that that is the cause of the common oil leak on the 4.4?
1200 rpm is just about ticking over Smile
G
Common Oil leak?
Post #519363 22nd Jun 2019 11:57pm
GraemeS
Australia
The turbo drain mod and the oil leaks in the V are different items. The drain mod provides an extra drain direct to the sump to overcome oil build-up in the inlet tract if the turbo isn't exercised regularly and the oil leak is from the oil cooler gaskets and/or the O-ring at the back of the oil cooler.
Post #519368 23rd Jun 2019 1:27am
