Home > Maintenance & Mods (L322) > Illuminated sill trim repair
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Drivers side doesn’t light up - there is power getting to the feed cable. Has anyone repaired one? Was thinking of stripping off the tape back and connectors and fitting a self adhesive led strip light in its place. Dies the lettering have a cover between it and the lighting strip? Any advice or help appreciated. Passenger side works fine. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #519040 19th Jun 2019 9:52pm
Danwilderspin
I don't have one on my sc but I have these on my m6 and the are a terrible design. Water penetrated through the tread plate over time and short the light tape out and it's game over. On those there is a dig to use a heat gun to separate and use some new light tape. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519042 19th Jun 2019 9:54pm
V8 Bob
Can get a 12v, 1.5 w led fibre optic light source and side skirt glow optical fibre cable that comes in varying sizes from 3 to 10mm might give it a try. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #519054 19th Jun 2019 11:04pm
Danwilderspin
Found the url I did it on mine
https://www.m5board.com/vbulletin/e63-bmw-...ics/170861 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519062 20th Jun 2019 7:41am
GGDR
Can't see the file DYI_ M6 Illuminated Door Sill Mod.pdf without a login Dan, any chance you could post somehow?
I repaired mine but not quite happy with it. I'll find the link.
. Cheers, Greg
Post #519063 20th Jun 2019 7:44am
GGDR
Found it:
https://www.fullfatrr.com/forum/topic44852.html Cheers, Greg
Post #519065 20th Jun 2019 7:54am
Danwilderspin
Sure will grab in a bit Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519069 20th Jun 2019 9:18am
kooky_guy
Mine were like that - I ended up buying a replacement set, but the light is still pretty feeble in them, especially if you have LED puddle lamps.
I've been looking out for something to upgrade the tape with - I still have the original plates to play with.
I did get a recommendation for some flexible LED strips, but I missed the auction and not spotted anything similar since. I'd certainly be interested in any recommendations. 2010 4.4 TDV8 Vogue SE
Post #519075 20th Jun 2019 9:40am
Danwilderspin
I have downloaded it but how can you upload files on here I have only ever done images? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #519084 20th Jun 2019 10:47am
