![]() | Home > General > Transmission Fault ? |
Andpopse Member Since: 16 Oct 2010 Location: Bristol Posts: 100 ![]() ![]() ![]() |
Hi Guys,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
i'd check your transmission fluid you might have a leak ... ... - .- -.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Andy, this may sound strange, but I just wonder if it might be related to your battery. I have a 2006 MY S/C, I have gearbox issues, and I'm pretty sure mine are caused by a failing battery giving low voltage, causing faults. Mine is particularly bad at idle, low revs, which is why your description rang a bell.
I phoned my local LR dealer who suggested it may be lack of lubricant at the selector cable / gearbox area. So I've decided to get transmission fluid changed and selector checked and lubed. The battery starts the car with good power even after 2 weeks of no use, but I will get it checked --- thanks for the suggestion.
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Ive just posted EXACTLY the same problem!!? If you have nothing nice to say,say nothing at all. |
Seems to be a common problem amongst S/C's all of a sudden!
Mines booked in for Wed morning....apparently a sofware update/TSB is needed.
Further Findings............. When in Drive if pull the gearleaver backwards, D reappears and I have drive. I have also found Sport / Manual does not give any drive.
Hmmmm |
No drive in Sport/Man whilst D has dissapeared or no drive at anytime? If you have nothing nice to say,say nothing at all. |
I didn't experiment enough, but could seem to get drive at all in sport/man. |
All fixed now and luckily not too expensive ! My gear selector and arm were seized, new arm fitted and set up, now it's silky smooth. |
Mine just fixed itself!!
Who fixed it and how much for future reference? If you have nothing nice to say,say nothing at all. |
