![]() | Home > Maintenance & Mods (L322) > Please help - horrific noise :-( |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2282 ![]() ![]() ![]() |
I meant to also say this hose had Popped off I think when I looked earlier on - would this cause that sound or am I dreaming - hopefully someone has some ideas I can look at this eve |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409 ![]() ![]() ![]() |
Hard to tell, but it sounds like a dry bearing.
Got the little hose on at lunchtime not sure if It’s any different
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Yes sounds like a bearing, maybe one of the beld-tensioner-bearings. |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
You are going to need to pinpoint the noise - I find a GS (giant screwdriver) helps in this regard.
Would you drive it or park it? Current stable:
NOT A TECH 1234 Member Since: 17 Jun 2019 Location: Earth Posts: 3 ![]() ![]() |
Depends on where the noise is coming from. Either way I wouldn't drive it, if one of those bearings stops then it will tear the belt and none of the auxiliaries will work. Best bet it to try and listen to where the noise is with a long screwdriver. Hopefully it's just a tensioner as they are a common thing to go. |
Ok so to anyone it doesn’t sound like a knackered supercharger or anything like that? I was wondering if i have a vacuum leak what the out of amplified sound coming from there are? Current stable:
Could be a bearing in the supercharger. Really easy to fix. They don't go wrong that often so I would start by isolating the noise. Take off the auxially belt and see if the noise it still there. That would tell you if it's the supercharger or not. |
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 82 ![]() ![]() ![]() |
I once left a washer on one of the studs between head and intake manifold on my girlfriends Porsche 944. It let air in, and made the gasket vibrate like the tongue in a instrument. It made such a noise I think all our neighbors heard it! I thought a bearing was dying first.
Ok - an update
Just a wild stab in the dark, but have you checked the oil level in the supercharger?
I tried the screwdriver but was trying to do fairly quickly as don’t like the noise as don’t want a serious problem - how can you check the supercharger oil level I saw a refill guide but is there a way just to check the oil in it?
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
Are your ltft plus 22?
