Home > Technical (L322) > Brake rotor vibration. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Are you sure it is not a sticky/seizing brake caliper ?
25th Jun 2019 6:22pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
Make sure the hub surface is clean when fitting new disks, check the runout using a dial gauge, its amazing how many people dont and then suffer premature failure of the new disks. BMW i3 Electric Car
25th Jun 2019 6:46pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
They were checked before installation Previous discs were vibrating also so 2 sets of faulty discs is low probabilty I must measure hub as Galaxy says. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
25th Jun 2019 10:54pm |
Make sure the face the hub is really clean, wire brush, emery paper, clean with brake cleaner. Fit the new disc (rotor) and measure the runout with the dial gauge. I got mine to less than 0.03 mm but I had several attempts. BMW i3 Electric Car
26th Jun 2019 5:50am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
check that caliper bolts are tightened properly 2012 TDV8 Black Edition
26th Jun 2019 7:36am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 897 |
It's also worth checking the rear discs/calipers as a sticking rear can feel like it's coming from the front.
26th Jun 2019 8:35am |
Will do this next time.thx. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
26th Jun 2019 2:39pm |
