Home > Technical (L322) > Brake rotor vibration.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
We installed new rotors since older ones were vibrating but new ones started vibrating just after installation.
What can cause the problem?Hubs?
I never had that problem in 10 years of l322 journey.
3rd one.
Now 150k km. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #519608 25th Jun 2019 2:07pm
Are you sure it is not a sticky/seizing brake caliper ?
Also, brake discs (rotors) are known to be out of balance / even new ones .
Post #519633 25th Jun 2019 6:22pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Make sure the hub surface is clean when fitting new disks, check the runout using a dial gauge, its amazing how many people dont and then suffer premature failure of the new disks. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #519634 25th Jun 2019 6:46pm
umitbat
They were checked before installation
Previous discs were vibrating also so 2 sets of faulty discs is low probabilty
I must measure hub as Galaxy says. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #519670 25th Jun 2019 10:54pm
AJGalaxy2012
Make sure the face the hub is really clean, wire brush, emery paper, clean with brake cleaner. Fit the new disc (rotor) and measure the runout with the dial gauge. I got mine to less than 0.03 mm but I had several attempts. BMW i3 Electric Car
Post #519679 26th Jun 2019 5:50am
nino_nino
check that caliper bolts are tightened properly 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #519682 26th Jun 2019 7:36am
mpirie
It's also worth checking the rear discs/calipers as a sticking rear can feel like it's coming from the front.
If a caliper is sticking you should notice extra heat coming from the affected side.
Mike
Post #519687 26th Jun 2019 8:35am
umitbat
Will do this next time.thx. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #519743 26th Jun 2019 2:39pm
