![]() | Home > Maintenance & Mods (L322) > Rear damper solenoid fault |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi,
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1858 ![]() ![]() |
Wiring is guilty of breaking just at the top of the electrical connector |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
Rear cable damage is not too common.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
Yes, that wiring and connector poking out of the top of the damper.
Thanks Graeme, looks like I need to strip the trim out & check under trim where you suggest.
Bit of digging & trim removal discovered the fault, both wires had broken right near the connector.
Glad you sorted it Rob.
Yes had a spare loom & tried it before wiring it in.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
I have the exact same issue on right rear! though i have just inspected the cable and it looks good? granted you cannot see much of it. I think i will order the repair cable and strip out the rear and replace as much as i can. is it possible it is just the plug is faulty?
