Home > Maintenance & Mods (L322) > Rear damper solenoid fault |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 396 |
Hi,
2nd Jul 2019 9:07pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1691 |
Wiring is guilty of breaking just at the top of the electrical connector |
2nd Jul 2019 9:30pm |
2nd Jul 2019 9:57pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Rear cable damage is not too common.
2nd Jul 2019 10:11pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2304 |
Yes, that wiring and connector poking out of the top of the damper.
3rd Jul 2019 2:31am |
Thanks Graeme, looks like I need to strip the trim out & check under trim where you suggest.
4th Jul 2019 9:06pm |
Bit of digging & trim removal discovered the fault, both wires had broken right near the connector.
10th Jul 2019 5:35pm |
Glad you sorted it Rob.
11th Jul 2019 6:26am |
Yes had a spare loom & tried it before wiring it in.
11th Jul 2019 11:53am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I have the exact same issue on right rear! though i have just inspected the cable and it looks good? granted you cannot see much of it. I think i will order the repair cable and strip out the rear and replace as much as i can. is it possible it is just the plug is faulty?
17th Sep 2022 11:41am |
