![]() | Home > In Car Electronics (L322) > Reverse camera removal - struggling please help |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Looks like it slides out backwards at a 45 degree angle, and the release tools need to go in straight down (cross covering the holding clips) to unclip the camera ? .
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Thanks Joe90, after much frustration I ended up breaking the housing. Now that its open I can see the trick is to push something very thin vertically down the slots and then apply some pressure in the direction of the sides of the housing. Problem is it's very difficult to apply pressure and get any leverage on the camera to pop it out. I found a video on youtube of a guy removing one but he makes a complete mess of the camera and housing plastic so I think better to sacrifice the housing than risk damaging the camera. |
In case anyone else ends up stuck on this I finally figured out how to do it without damaging the camera or the housing.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Thanks - I'll have another go at removing mine once I find some tools.
It's not difficult once you have seen how it fits together but the instructions in the workshop manual were written by the chocolate teapot dept at LR.
Thanks. I made tools from an old hacksaw blade that worked a treat after seeing what's required, particularly giving the tools a light tap to spring the tabs.
That's great news GraemeS - glad it worked for you! |
The earlier bracket isn't compatible with the later camera which also is deeper and is the reason why the later cameras are mounted in a different position so as to clear the stop light. Both cameras are working now and the hacksaw blade tools stored with the original spoiler. |
Yes I noticed they’d changed the brackets at some point. I saw instructions for the older one which had a screw to be removed to remove the camera.
