![]() | Home > Technical (L322) > Danger - anyone else had a tow bar detach mid journey? |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I believe there are a couple of types of detachable towball used by Land Rover. One i believe was LR's own make and was subject to a recall, it suffered premature wear and became a loose fit in the receiver. On mine it has the Westfalia one, the same design I used for years on my Touareg and doesn't have any such issues.
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
Yep that was the disco/rrs one the plugs into the rear crossmember directly and when left in it could rattle about and make the hole too big so the unit could come out.
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 627 ![]() ![]() ![]() |
OK thanks. I've never seen that LR one before, only ever had the Westfalia swan neck on any of mine which is what John had too so its really their one that we are interested in.
I got mine from pf jones as a complete fitted solution (for my last 2 L322's) but this looks to be just the hitch for the 2inch receiver.
Hmmm thanks again...but not sure that would work with mine as I've got the late body kit which looks like it may come too low and too far back. Mike - MPx
Works with my 2012 AB Current: RR L322 2010
Interesting...do you have the extended body kit on yours?
Would appear not
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
I guess that problem won't happen here in Oz, we use this type of towbar tongue (this is mine).
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Farmers Hitch here |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
@P38. How do you get on with different trailer heights? John
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
same here, I went for the farmers hitch because removed it looks less intrusive than the westfalia swan neck one. I got mine from pf jones also. my only concern is that some scroat could unpin the trailer very easily, so if I'm leaving the car and trailer I tend to padlock the two together. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
It’s the same system in the US - you can buy hitches with different amounts of ‘drop’, so you get the right one for your vehicle / trailer combo |
