Home > Maintenance & Mods (L322) > Brembo Caliper Pins!
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Well.....what a pain in the neck to get the retaining pins out of my brembo callipers this afternoon. After copious amount of heat with my little max gas oxy turbo set I finally drifted the last bottom part out.....who thought that carbon steel and alloy would go well together??
Ended up cleaning the passenger side caliper and used copperslip on the pins/retaining pin holes. My next question is....
What’s the best technique to get the caliper bolts out so I can swap the discs out? I have an impact driver so assume I have to put the steering on full lock to get the impact driver in or use a huge breaker bar? What’s the best place to buy the bolts and the impact socket?? The bolt is a star shaped head??
Any ideas guys?
Best regards
Mark
Post #521026 7th Jul 2019 11:35pm
A 22mm socket and a breaker bar is what you'll need sir Thumbs Up
Post #521027 7th Jul 2019 11:51pm
nino_nino
bolts are 21mm 12 point, use some Loctite when reinstalling. if you polish pins and applied some nano coating it will prevent them from sticking. Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #521037 8th Jul 2019 8:35am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
is it good to use copper on alloy RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #521038 8th Jul 2019 9:08am
Mikey
No, copper grease will react with the aluminium caliper, and corrode
Ceramic grease is what should be used Thumbs Up
Post #521047 8th Jul 2019 10:14am
nino_nino
use aluminum or nickel paste.
https://www.amazon.co.uk/s?k=Permatex+8007...nb_sb_noss 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #521073 8th Jul 2019 2:52pm
