![]() | Home > Technical (L405) > My Car Fixed Used LTB00557V10 TECHNICAL BULLETIN 27 JUL 2018 |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2715 ![]() ![]() ![]() |
Ok, so a really daft question. Are technical bulletins simply a job guide to fix a problem or are they almost like a recall?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Mr Tee, a daft question no sir... I simply went to my nearest main agent and booked a slot (with a loan car, which i think is important as they want it back asap!!!)
Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128 ![]() ![]() ![]() |
Well done. I rejected my Lookers car because I got bored arguing with them that all they needed to do was go through every step in the TB. |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
ha ha - I just recently had mine done....when I test drove it after (with the master tech) ...the sound of silence was so good I could have kissed him! |
ilard Member Since: 21 Oct 2012 Location: London Posts: 715 ![]() ![]() |
But how did you get your hands on that Tech Bulletin document, is it simply via a paid Topix account? Is there a free way? |
Somebody posted it here a while ago iLard... Technical Bulletins are usually quite easy to find on line and often get posted on owners forums sir |
I have a copy - PM me an email address if you want it. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
Apart from the knocking (or lack of it) is it easy to check which valve block you have and how much to swap if old type? Geoff |
cost to change at a main dealers is aprox £1500 inc labour. - though all things playing fair, LR should cover that cost (note it's LR, Not extended warranty - who will refuse any claim) |
The front active anti roll bar is a further £1900...
When my car went in for its MOT i asked/no, i challenged the tester to find where the knocking noise was coming from! He 100% could not so, this then gave me the confidence to book it in to the local main dealer quoting the TSB number to them!
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
Cam, it really |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1115 ![]() ![]() |
What I do not understand is why a manufacturer who is laying off 4500 staff because of poor sales is allowing customers to be so |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 549 ![]() ![]() ![]() |
I strongly suspect that the lay offs have more to do with reorganisation wrt electric vehicle production than they do for any thing else. It's been a very cynical move and explains Speth's constant moaning about how Brexit will ruin JLR, there's his excuse for the lay-offs.
