![]() | Home > Technical (L322) > Sensor in the spare wheel well on L322 |
| sniper Member Since: 21 Apr 2019 Location: london Posts: 23
Ah ha.... perhaps then.. i did not know that the spare was monitored.... |
Its an accelerometer for the 2009> active suspension... Otherwise known as a yaw sensor |
Ah ha... thats what it looks like..... what does it do? (like in response to various yaw or accel/decel inputs?) |
TPMS sensor/reciever's are on the rear of your inner wheel arch/splash guards sir and look like a plastic ariel |
tho.. when i google Range rover Yaw sensor none of the pictures look like the one in my spare wheel well.... |
There are several of them around the car and they all sense body roll as you travel, then the system adjusts the active shock absorbers to suite |
Called a lateral accelerometer... Here is the same thing for a D2 https://www.google.com/search?client=safar...cbKu221eM: |
Gotcha, thx folks..great info..... not a great placement of the sensor if you are chucking the spare wheel back in't hole.... but now i know i need to be very careful of it |
| Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245
Oh well, pretty sure the spare on my 2007 was monitored as well (I had enough trouble with the TPMS).
The spare on your 07 will be monitored sir... TPMS works on all five wheels 👍 |
Yes it was monitored......when it felt like it |
| All times are GMT |
