![]() | Home > Technical (L322) > Restricted Performance fault TDV8 4.4 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
I made my own intake hoses from 70mm ID black silicone hose - each 55mm long. I re-used the original clamps. |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Awesome, thanks Graeme, just ordered some up so I can fit over the weekend. Even if it isn't the boots leaking the FF has done 90k now so going to go soon anyway |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
Dirty black soot is usually found near the split.
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
nice tip Mike, |
Westminster_Bri Member Since: 17 Jun 2019 Location: Gloucestershire Posts: 31 ![]() ![]() ![]() |
I had a split in one of mine a couple of weeks ago, exactly the same issue and the split was right under the jubilee clip. I 'tweeked' the jubilee clip and managed to get her going again for another week until I could get the part. (low revs with minimal boost).
Good tip Mike - I will try that.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4349 ![]() ![]() ![]() |
Was it these? Doesn’t say if it is for 3.6 or 4.4 ![]() https://www.britpart.com/parts/performance...ses/da4580 https://www.island-4x4.co.uk/silicone-hose...34045.html Perhaps they fit both? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
I'm assuming we are talking about the same parts here...
@DrRob - those are for a 3.6 not 4.4 unfortunately |
Yup, and pointed out in the pic below (apologies for the crude mark up!) - Came in at £24.75 each
Silicon 70mm x57mm couplers are available on eBay,
Sorry, ignore me ![]() ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
So had a go at this this arvo, still couldn't see a leak anywhere even with the wife revving the engine with me under the hood so bit the bullet and took of the inlet mainfold.
Excellent news |
