![]() | Home > Technical (L322) > Adaptive Dynamic Fault L322. |
Mikem Member Since: 13 Jan 2019 Location: Kent Posts: 48 ![]() ![]() ![]() |
Any recommendations in the kent area for getting the car plugged in to try and find the fault |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
If any member has still got the old wiring, particularly the plastic plugs that fit into the top of the strut, please don’t bin them,... PM me and I will gladly pay postage for them.
timse Member Since: 06 Dec 2019 Location: Farnborough Posts: 37 ![]() ![]() ![]() |
Hi Andy, Do you happen to know what the part number or where to get the repair kits please. I too have a L322 5.0 S/C 2010 that has just popped the error up on the dash so want to replace these cables on the front struts before anything else. Thanks for your help Tim |
Perfect, many thanks Mike |
CaifanSC Member Since: 25 Dec 2018 Location: Maryland Posts: 36 ![]() ![]() ![]() |
Did the OP ever find the fault? 2012 Range Rover Autobiography
FlyingTrotter Member Since: 10 Nov 2013 Location: London Posts: 79 ![]() ![]() ![]() |
I have just had the Adaptive dynamic fault - pop up on the dash - my vehicle is a 2011 4.4 VSE and the terrain mode doesn’t work and it drives like there is no damping at all - very unforgiving
It’s usually a broken wire to the top of one of the front struts.
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
Hi Mike, I may be being thick but I can't find that seller online. Would you have a link please? Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
You could ring Rob at Duckworths, mention the forum and quote the part number.
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3334 ![]() ![]() ![]() |
Mine was caused by a loose connector to a height sensor. I fault scan with a GAP IID tool or your indy should locate the component that has failed. 2012 TDV8 Vogue (L322) |
All sorted - was fortunate to be able to get them to spare the time to check and it was a broken wire to the front story - all now right again - Bloomin fortunate as have a shoot just after NY
