![]() | Home > Technical (L322) > Not Starting |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
I have had this twice? stopped the car after a drive ie: turned off the ignition, foot on the brake to start press button to start and the dash message is foot on the brake to start? as I already have my foot on the brake I can't understand why I get the message? I then shut down get out of the car lock the car wait for the computers to shut down and start again and it works after two times of pressing the foot on the brake as usual?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
The suggestion is only made as a temporary fix.
Hi, Mike on thinking about the starter I did hear a click from the starter which would point to that as the problem, could anyone point me where to source the parts to fix it myself? as I read your`s and others post.
It’s a couple of months since I searched for the best deal, but Opie Oils was the best deal with free delivery.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Just check all the connections first, including the earth straps. easier and cheaper....
Thanks, I will check them aswell |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1025 ![]() ![]() |
What engine is this tinman ? |
2011 4.4 v8tdi |
It will just be the contacts in the starter motor just order a rebuild kit easy fix |
Where do you order them from? |
I got mine off the bay of thieves loads of sellers on there doibg denso repair kits |
We have all failed to find a repair kit for the 4.4 tdV8 starter motor. solenoid contacts.
Ok i have messaged the guy i use who got me a kit for my m62 4.4 petrol most of the kits are very similar they even do a genral one that fits a dozen or so denso starters |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 911 ![]() ![]() ![]() |
TBH, by the time you've taken out the old starter to replace the contacts in the solenoid, you'd be better off (and more confident of a permanent fix) if you just replaced the whole starter.
