Home > Technical (L322) > intermittent rotational knocking
kobi30
Scotland 2010 Range Rover Autobiography TDV8 Oslo Blue
2010 3.6 tdv8 have had this ff for 7months now all is fine except the intermittent knocking/thumping noide I get when accelerating from a standstill.have had it at 2 local garages one a respected l/r independent and the other a transmission specialist neither have been able to replicate the fault so unable to offer a cause.
it happens on normal acceleration and only from standstill but not all the time I can best describe the noise as what ive experienced before on older rwd cars when prop shaft centre bearing has gone.
I have had the gearbox reconditioned after problems with 5/6gear and had hoped this may have flagged a problem but specialist who carried out work advised nothing wrong to cause the symptoms.
when it does happen its only brief but have put box into neutral and im sure it stopped which would point to a transmission problem.
sorry for the long post but getting frustrating now and due a trip to devon soon would rather have it resolved before then
thanks in advance all input appreciated
Post #523506 1st Aug 2019 2:00pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
whats the front prop to the front diff like , they can wear and make a clunk as you pull away
Post #523510 1st Aug 2019 2:51pm
kobi30
thanks for the input will have a look at that tomorrow Very Happy
Post #523515 1st Aug 2019 3:12pm
bembo449
you do that , at least its easy to check , just grab hold of it and if you can move it easily its goosed
Post #523544 1st Aug 2019 8:56pm
kobi30
right as advised checked front prop all nice and tight no play in that or rear prop.did notice a leak from transfer box is this a possibility.
thanks for any input the only thing marring my fantastic fatty
Post #523628 2nd Aug 2019 7:16pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Mine started with a very light ticking noise at certain speeds and usually just on very light throttle. It stayed like that for 1000's of miles before suddenly developing into a much more pronounced vibration. I had a look around and couldn't find anything conclusive, in the end, it turned out to be rear propshaft centre bearing. New propshaft, fault cured. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #523651 3rd Aug 2019 6:49am
kobi30
thanks will take a closer look at that
Post #523656 3rd Aug 2019 8:15am
