![]() | Home > Technical (L322) > intermittent rotational knocking |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 817 ![]() ![]() ![]() |
whats the front prop to the front diff like , they can wear and make a clunk as you pull away |
kobi30 Member Since: 09 Feb 2019 Location: Edinburgh Posts: 4 ![]() ![]() ![]() |
thanks for the input will have a look at that tomorrow |
you do that , at least its easy to check , just grab hold of it and if you can move it easily its goosed |
right as advised checked front prop all nice and tight no play in that or rear prop.did notice a leak from transfer box is this a possibility.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Mine started with a very light ticking noise at certain speeds and usually just on very light throttle. It stayed like that for 1000's of miles before suddenly developing into a much more pronounced vibration. I had a look around and couldn't find anything conclusive, in the end, it turned out to be rear propshaft centre bearing. New propshaft, fault cured. BMW i3 Electric Car
thanks will take a closer look at that |
