![]() | Home > Technical (L322) > Inactive/active suspension after Battery changes |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
I just spent two hours with the suspension set ups on Gap and really no further forward. I ended up with all four levels on the bottom and wouldn’t raise , one side , the left side had been an inch lower . That maybe insignificant so took the car out ,( it does say no faults at the moment ) and when I got back the rear is up but not the front , got out shut the door and the rear went up another half inch .
I need to know from the GAP tool what menu I use to set height , I am all over the options . |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
There is something wrong with the EAS....
Thanks for your help , coincidental that I had changed the battery !
and Ouch ! .
Shame there was no direct fault codes then , might have saved time.
