|  | Home > Maintenance & Mods (L322) > TDV8 turbo intake pipe loose |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      |
|  4th Aug 2019 3:21pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | Seems very loose. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  6th Aug 2019 9:46am |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | I applied some vaseline to mine to improve the seal. It was snug though already. The rubber flange seemed to grip well.  Otherwise it would drag in a load of dirty air or water... __
|  6th Aug 2019 10:54am |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | Did it ever cause a fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  6th Aug 2019 11:14am |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | No. I did a smoke test and no leaks after I'd rebuild and refitted the engine.
|  6th Aug 2019 11:23am |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | So if that’s happened to mine would you say it would cause a fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  6th Aug 2019 11:37am |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | Whats the fault code you are getting? __
|  6th Aug 2019 1:17pm |
|  6th Aug 2019 2:41pm |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | That's highly likely to be your inlet manifold.
|  6th Aug 2019 3:25pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | I had a smoke test done last week and the inlet manifold was fine.
|  6th Aug 2019 5:37pm |
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797    | How hot was the engine when you had your smoke test?
|  6th Aug 2019 9:28pm |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | It was up to temperature as I’d driven to the garage just before the smoke test. The only leak was the hole in the air tube which I’ve replaced. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded | ||
|  7th Aug 2019 3:53am |
| j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 389    | Mine would not show unless it was operating temperature and after a run.
|  7th Aug 2019 7:00am |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951      | I think this car came with a multitude of problems which is why the previous owner sold it. He knew exactly what he was doing when he sold it to me.
|  7th Aug 2019 7:22am |
| Posting Rules
