Home > Maintenance & Mods (L322) > TDV8 turbo intake pipe loose
Andy
I replaced the air intake pipe the other day as there was a hole in it the size of my little finger just near the U bend.
I noticed when I pulled the convoluted section off the hard plastic pipe to the turbo, I could move this pipe around like it was loose. I could also see what I thought was a plastic seam opening and closing.
How do they connect to the turbo and should there be movement? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523750 4th Aug 2019 4:21pm
j_rov
Pretty sure it's just push fit. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #523804 5th Aug 2019 12:30pm
Andy
Seems very loose. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523877 6th Aug 2019 10:46am
j_rov
I applied some vaseline to mine to improve the seal. It was snug though already. The rubber flange seemed to grip well. Otherwise it would drag in a load of dirty air or water... __
Land Rover History:
1976 Series 3 2.25
Post #523885 6th Aug 2019 11:54am
Andy
Did it ever cause a fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523889 6th Aug 2019 12:14pm
j_rov
No. I did a smoke test and no leaks after I'd rebuild and refitted the engine.
The rubber seal will shrink though so best replace if it's not snug on yours. __
Land Rover History:
1976 Series 3 2.25
Post #523890 6th Aug 2019 12:23pm
Andy
So if that’s happened to mine would you say it would cause a fault? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523891 6th Aug 2019 12:37pm
j_rov
Whats the fault code you are getting? __
Land Rover History:
1976 Series 3 2.25
Post #523895 6th Aug 2019 2:17pm
Andy
Post #523902 6th Aug 2019 3:41pm
j_rov
That's highly likely to be your inlet manifold.
I'd guess at the second pot in from the front on the right hand side (looking from drivers seat)
You can see it normally on the engine cover foam. Pull that off and examine, it should give you a clue to the location.
Failing that, have you still got EGR valves? __
Land Rover History:
1976 Series 3 2.25
Post #523907 6th Aug 2019 4:25pm
Andy
I had a smoke test done last week and the inlet manifold was fine.
The EGRs have been blanked off and digitally removed 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523919 6th Aug 2019 6:37pm
cass
How hot was the engine when you had your smoke test?
I only ask because a smoke test on my warm engine didn't show anything up but it did show bubbles when it was hot.
Post #523931 6th Aug 2019 10:28pm
Andy
It was up to temperature as I’d driven to the garage just before the smoke test. The only leak was the hole in the air tube which I’ve replaced. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523940 7th Aug 2019 4:53am
j_rov
Mine would not show unless it was operating temperature and after a run.
I wonder if your big leak in that pipe meant smoke didn’t build up thru the whole system?
You could try washing up liquid in water sprayed over the plastic manifold.
I’m not sure the error message would show because of a leak on the intake pipe as it’s not pressured there. __
Land Rover History:
1976 Series 3 2.25
Post #523943 7th Aug 2019 8:00am
Andy
I think this car came with a multitude of problems which is why the previous owner sold it. He knew exactly what he was doing when he sold it to me.
I should’ve sold it when I bought it but I’m too honest with people. I’d be declaring all the faults because that’s the way I am.
Despite its faults I’ve grown to really like the car so I’ll persevere with it. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #523946 7th Aug 2019 8:22am
