Home > Technical (L405) > Cubby Box Cooler
supershuttle
Cubby Box Cooler
I've tried different combinations in the search but come up with nothing, hence this post.
My cooler/fridge thingy in the front central console doesn't seem to get cold (or even very cool), is this normal? are there any checks I can run? anyone got any other observations about theirs? Geoff
Post #523765 4th Aug 2019 8:25pm
Have you checked the fuse ?
I only ever use mine on long runs - it seems to take an hour or so before drinks are noticeably cooler
Post #523769 4th Aug 2019 8:59pm
when you click the switch does the indicator light come on? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #523770 4th Aug 2019 9:06pm
supershuttle
The light comes on, I assume that means I don't need to check the fuse - or do I?
It just doesn't get cold, I don't expect it to be freezing but it seems to me that its hardly cool even on long journeys. Geoff
Post #523791 5th Aug 2019 10:22am
unless theres a break between the switch [which is getting power] and the cool box itself then i reckon thats as cool as it will get...ive never used mine for cooling, i use it for storage.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #523793 5th Aug 2019 10:29am
Baltic Blue
Stick a thermometer in there for a couple of hours ??
Post #523794 5th Aug 2019 10:32am
supershuttle
Thermometer ordered Thumbs Up Geoff
Post #523813 5th Aug 2019 1:11pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
don't be expecting miracles from this thing. Ive had them in the last 3 land rovers and they are pretty feeble. Unless on quite a long run, you will not likely notice anything and even after a long run, things will only be marginally cooler.
Post #523929 6th Aug 2019 10:16pm
supershuttle
Ah, so the most I can expect is that it will stop my chocolate from melting Rolling with laughter Rolling with laughter Geoff
Post #523937 6th Aug 2019 11:29pm
Mr Tee
Was on a long run with a couple of juice cans in there, surprisingly cold they were! Maybe a group buy on thermometers, someone do an excel with the results Laughing Thumbs Up
Post #523947 7th Aug 2019 8:30am
We drove to midlands airport on Monday morning and my Bon Bon’s were rock hard and very cold!!! 😝👍
Post #523951 7th Aug 2019 9:17am
ianmacd
United Kingdom 2010 Range Rover Vogue TDV8 Epsom Green
On saturday we had left a can and small bottle of water were in there during the day and they were quite warm when we got back to the car. On the trip back, after about an hour I drank the can, and while not freezing cold it was quite cold after that time. I had put it right at the front so it was where the cold air comes in. Current: RR L322 2010
Past: RR L405 2017, RR L322 2012, 2008 & 2004, 2018 D5, 2016 Defender, 2011 D4, a few Disco2s, P38, RR Classic, couple of Disco1's, SIII SWB
Post #523954 7th Aug 2019 9:38am
EdJ
The fridge on my 2018 AB is in a different league from the fridge in my 2014 AB. The newer one has two settings - with two lights it's fast freeze and it does seem to get the drinks icy cold quite quickly.
In the 2014 car, it was reasonably effective. 2024 Range Rover P550e AB
Post #523973 7th Aug 2019 2:27pm
supershuttle
Mine is a 2013 so clearly not as good as later ones but the opinions seem mixed. I'm waiting for a thermometer so when I get it I can take some definitive readings rather than the subjective stuff which seems to blow hot and cold (and not so cold Rolling with laughter ) Geoff
Post #523976 7th Aug 2019 2:49pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
My 2015 car has a fridge which keeps things acceptably cool. Trick might be to keep a bottle of water in it?
Post #524009 7th Aug 2019 7:04pm
