![]() | Home > Technical (L405) > Cubby Box Cooler |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3940 ![]() ![]() ![]() |
I've tried different combinations in the search but come up with nothing, hence this post.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
when you click the switch does the indicator light come on? ... - .- -.
The light comes on, I assume that means I don't need to check the fuse - or do I?
unless theres a break between the switch [which is getting power] and the cool box itself then i reckon thats as cool as it will get...ive never used mine for cooling, i use it for storage.. ... - .- -.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3864 ![]() ![]() ![]() |
Stick a thermometer in there for a couple of hours ??
Thermometer ordered |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
don't be expecting miracles from this thing. Ive had them in the last 3 land rovers and they are pretty feeble. Unless on quite a long run, you will not likely notice anything and even after a long run, things will only be marginally cooler. |
Ah, so the most I can expect is that it will stop my chocolate from melting |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
Was on a long run with a couple of juice cans in there, surprisingly cold they were! Maybe a group buy on thermometers, someone do an excel with the results |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
We drove to midlands airport on Monday morning and my Bon Bonβs were rock hard and very cold!!! ππ |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 ![]() ![]() ![]() |
On saturday we had left a can and small bottle of water were in there during the day and they were quite warm when we got back to the car. On the trip back, after about an hour I drank the can, and while not freezing cold it was quite cold after that time. I had put it right at the front so it was where the cold air comes in. Current: RR L322 2010
EdJ Member Since: 30 Jan 2015 Location: London Posts: 366 ![]() ![]() |
The fridge on my 2018 AB is in a different league from the fridge in my 2014 AB. The newer one has two settings - with two lights it's fast freeze and it does seem to get the drinks icy cold quite quickly.
Mine is a 2013 so clearly not as good as later ones but the opinions seem mixed. I'm waiting for a thermometer so when I get it I can take some definitive readings rather than the subjective stuff which seems to blow hot and cold (and not so cold |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1083 ![]() ![]() ![]() |
My 2015 car has a fridge which keeps things acceptably cool. Trick might be to keep a bottle of water in it? |
