Home > Camping, Caravanning and Holidays > Towing with a 4.4 TDV8 |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 343 |
Tow a Sterling Eccles 580 with my 4.4 tdv8, ULW 1362kg. Is absolutely effortless left alone will normally be in 7th gear at 50 but will pull 8th at 60 sometimes just need to manually change up! Furl consumption towing is circa 24 mpg v 30 solo.
6th Aug 2019 8:25pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1459 |
2000Kg Bailey Senator Wyoming twin axle with all the weight upgrades etc. I used to tow with a 3.0 V6 Touareg and thought that was good (it was). The 4.4 TDV8 old fatty is in a different league altogether, the gearbox is a gem, doesnt hunt gears and as V8 Bob said 7 th gear until mid 50's and then 8th, up hill, downhill no problem at all. Buy one, worry not at all. BMW i3 Electric Car
6th Aug 2019 8:35pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1131 |
Hi, I have a large Vanmaster heavier than most tow`s it well and deliver`s very good mpg I too came out of a VW 3.0 and that did the job but not as comfortable as the FFRR |
6th Aug 2019 10:22pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 662 |
I had a hunch it would be ok, just needed reassuring the low revving engine didn't hinder towing.
6th Aug 2019 11:41pm |
I bought my Fatty 3 years ago with 90k with not much history then set about replacing all the fluids, brake pads etc even with full history you can still have some things to replace? a 2012 car now is 7 years old if you want something reliable buy a walking stick? cars brake down its only to be expected. Mine has not let me down yet, that's why we buy insurance AA RAC Green flag etc, Look for a car that you feel good with It will do all you ask in towing your Tin tent and will get you there in comfort. |
7th Aug 2019 7:39am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
I did nearly 45,000 miles towing 2000kg vans and never had a single problem, got about 19mpg.
7th Aug 2019 10:30am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
The 4.4's pull like a train from very low revs. Titan engine. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
7th Aug 2019 11:18am |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
I towed my 2000kg Buccaneer with the 4.4 and it was no bother at all, to be honest the 3.6 was good too! These cars have so much low down grunt you just don’t notice anything behind them. I used to keep it in sports mode so it hangs on to gears a bit longer and use the paddles as well. You just knock it down to 7th or even 6th if you feel it struggling a bit. Your bailey caravan is quite lightweight also, so no worries at all Current: TDV8 (3.6) RRS HSE
8th Aug 2019 6:34pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4226 |
https://www.fullfatrr.com/forum/topic52154.html Pay the man 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 on order so "Rory" will be going to a new home....! 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
8th Aug 2019 6:52pm |
