![]() | Home > Maintenance & Mods (L322) > Battery Replacement 2011 TDV8 4.4 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8755 ![]() ![]() ![]() |
Just did this swap today, took about 20 mins start to finish.
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159 ![]() ![]() ![]() |
Did you ever get an answer to this ? Did you change your battery OK ? I'm faced with same problem... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Lots of folks have changed and not bothered telling the car it has a new one via an IID and had no issues. I would suggest it is fully charged before fitting it. Even if new from the shop, stick it on a charger Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks :¬) Its never easy these days... |
Still not coded mine and so far so good. And yes the FBH is now up and running properly. There is nothing that can't be fixed with a hammer😜😜
Useful video for this thread
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Just changed my battery but cannoit find where within the Gap IDTool menu system the option to confirm battery type is. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3839 ![]() ![]() ![]() |
From memory it is in the Body Control Menu.
Thanks, |
If I go to "Control I/O" and then ""BCM-Body Control" I only find:- Alarm LED Outputs - Front wiper fast Outputs - Front wiper on relay control Outputs - Headlamp high beam left supply Outputs - Headlamp high beam right supply Outputs - Headlamp low beam left supply Outputs - Headlamp low beam right supply Horn relay Alarm sounder Outputs - Secondary tailgate release supply Outputs - Tailgate/trunk release supply I have a good look at the available menu options but still cannot find the "Battery" option. Can anyone point me to the full menu path to it? Many thanks 2010 Range Rover TDV8 Baltic Blue Autobiography (2011 MY) - SOLD ![]() 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
You are correct! ![]() It can be found under:- * Service / Test * BCM - Body Control * Battery Replacement Took me a while but you can just see the menu in one of the earlier posts in this thread. I am a bit slow but got there in the end. ![]() ![]() 1960 Land Rover SII SWB SW 2020 BMW R1250 RT LE 2021 Triton ST-125 (Monkey Bike) |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Whilst on this subject. I know the 10-11 vehicles had an issue with battery.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2618 ![]() ![]() |
Had the battery warning from new, dealers were useless - it would even give the “Start engine” message when you opened a door whilst a smart charger was connected. |
