Home > In Car Electronics (L322) > Newer infotainment modules?
Danwilderspin
Hi there
So my Bluetooth is broken in My 07 and looking on here it seem that you can put a 2011 module in so I have ordered one.
If that works from the newer system to the old - does the iPod interface? Or the dab interface as it still uses most? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524216 9th Aug 2019 10:42am
different i-bus bit rate... ... - .- -.
Post #524220 9th Aug 2019 11:10am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Did you check for compatibility with the earlier (2007 MY) electronics ?
2011 sounds almost too new. There has been discussion about the later models fibre optic system operating differently vs earlier.
When I upgraded ours ( late 2006 model) I used module part no. AH42 10F845 AA - but I'm not sure which model year it was fitted to originally.
Edit : Stan beat me to the comments - lol Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #524221 9th Aug 2019 11:12am
Danwilderspin
This is what I have bought looking at wiggs diy thought it would be ok doubting now...
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524233 9th Aug 2019 12:49pm
Danwilderspin
Aha
This is what I must have looked at
https://www.rangerovers.net/threads/new-bluetooth-module.32997/
Now if the Bluetooth module does work from newer has anyone tried any of the others as surely they use the same bus? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524235 9th Aug 2019 12:53pm
Pawl
That part no looks very close to the one I used successfully - only the initial 8 & A are different.
I think that's probably going to work. Paul,
Post #524247 9th Aug 2019 1:48pm
Danwilderspin
thanks - but that leads to my question - how can the bluetooth work on the new and old systems? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524249 9th Aug 2019 1:53pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I think some of the other units may rely on the screen as well as the unit themselves.
Obviously the screen is a bit different on the L322 to a Disco but you can put an early Disco 4 screen in a Disco3 but the post 2012 stuff runs on a different bit rate. I suspect it is also to do with the interface that runs the MOST loop.
Post #524276 9th Aug 2019 5:41pm
Pawl
I'm wondering when the CANBus system changed - whether it must have been later.
I found the info that I had originally & it confirmed the AH42 10F845 AA & 8H42 10F845 AA were interchangeable, but no explanation of what was different between them. It also suggested they were both used on vehicles upto 2010. So maybe the CANBus change was after that. Paul,
Post #524289 9th Aug 2019 7:19pm
Danwilderspin
Yea but that wouldn’t make sense to change half way through the later infotainment setup ... hmmm Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524437 11th Aug 2019 8:21am
GraemeS
Australia
The canbus changed on MY10 L322 and L320 RRS and the D4 was introduced at MY10 with the new canbus specs. If the VIN has the A or later year indicator preceding the 6-digit number then the vehicle has the new canbus.
Post #524439 11th Aug 2019 8:29am
Danwilderspin
Yea which is when they swapped to fomoco by right? So what I do t get is why that works and anything else wouldn’t or has it not been tested? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #524495 11th Aug 2019 10:52pm
