![]() | Home > General > Whats wrong with getting a TDV8 Vogue? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
What? They have the same kit in them, same screen, sat nav, etc etc. So any issues with one will affect them all. Westminster’s are a bit later, but they sometimes have less standard equipment. So check wisely. I love my Vogue SE....
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Turbo drain mod only needs fitting if the car smokes out the back when you boot it
https://www.fullfatrr.com/forum/post524626.html#524626
None of the cars ever had turbo drain mod from factory. Some got done under warranty later, but I think if customer didn’t have an issue, it was never done. Some never needed it to this day. 2011 Range Rover Vogue SE 4.4 TDV8
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Duff info - there are no issues at all between Vogue, Vogue SE, AB or Westminster. Same mechanicals, same electronics, except the higher models have more 'stuff'.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 with all the above comments, I had a VSE that had a good bit of equipment. Mine didn't have the drain mod , was remapped and never gave a puff of smoke or any trouble of any kind. Sorr of regret changing it. Fantastic machines . Obviously an Autobiography would be best for spec but you might be limiting yourself re choice. 2015 4.4 AB
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 ![]() ![]() ![]() |
Thanks for the advice gentlemen. About what I figured. No real differences just, as ever, buy a good one.
The earlier the 4.4TDV8 the higher the spec! They took all the standard kit away in 2011 and made it optional! |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
+1
