Home > Maintenance & Mods (L322) > Blind spot mirror upgrade nightmare! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2300 |
I'll have a look later at what my IIDTool shows for my MY12 that was built with blind spot monitor. |
14th Aug 2019 3:56am |
I can only find 2 references in the IIDTool's full CCF display, both having the description "Side object detection" with the 1st having the options of undefined, not fitted or fitted and the 2nd having only the options of fitted or not fitted.
14th Aug 2019 9:30am |
georgekale Member Since: 16 Jul 2015 Location: IL Posts: 17 |
I need to find a way to change the original CFF? I got the Globe closing to work. Instrument panel reads side object fault.
14th Aug 2019 3:01pm |
The cause could be a wiring fault (eg improperly fitted connector) or a fault with the mirror itself or software needs updating, probably the BCM and possibly also the door module. |
14th Aug 2019 9:57pm |
No its CCF fault. I have to program the BCM to turn on the right blind spot module.
15th Aug 2019 12:36am |
I wondered if the 2 entries listed by my IIDTool were for left and right and if so then the descriptions could do with the extra left/right notation. Perhaps driver and passenger sides? |
15th Aug 2019 12:39am |
Still working on it. Can anyone steer me in the right direction to fix this problem.
18th Aug 2019 4:59pm |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 44 |
Did you ever solve the issue? Im currently trying to program my system I retrofitted. Im seeing two option for "Side Object Detection" one lets me choose "Fitted" or "Not Fitted". Another shows "Undefined", "Without side object (blind spot) detection system", "Side object (blind spot) detection system with radar 'Direct LED'", and finally "Side object (blind spot) detection system with rear traffic detection". I am not sure for the second which I should do. My issue is that the amber light is remaining permanently on when im in park, drive (at various speeds), and in reverse. |
23rd Jan 2021 3:09am |
I only found in the CCF "side impact detection" as "fitted" in mine which has blind spot monitoring. Perhaps if I had selected the option rather than "no changes" then more options may have been shown. I'll have another look a little later.
24th Jan 2021 1:56am |
25th Jan 2021 9:17pm |
Mine doesn't have options other than fitted / not fitted. Perhaps US vehicles got a later configuration file. In case its significant, I spotted Side Camera - both left and right.
26th Jan 2021 9:54am |
At this point Ive verified the component I got. The brackets are mounted correctly, the modules and parts came off the same year Range Rover, and the mirrors are attached properly. I have no idea what else I could try, Im pretty sure its an issue with the Gap tool since I can't even get the menu to pop up in my instrument cluster |
4th Feb 2021 3:39am |
I use my Android phone with my Gap tool, not the instrument cluster. |
4th Feb 2021 7:34am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
I'm with Graeme on this.
4th Feb 2021 12:34pm |
